View Poll Results: Which Meth Kit?
Voters: 19. You may not vote on this poll
Lets Start Over, "Which Meth Kit Poll"
#24
Originally Posted by moregrip
I merged your threads, no need for two threads addressing the same question btw, a mod could have added another poll choice for you
Jim
#27
I have the Snow Performance stage II MAF variable controller kit.
I believe on a roots style blower that makes boost instantly at low rpm
that the MAF controller type is better that a varriable boost controller.
Here's why:
You hit the GO pedal boost climbs instantly to 10psi by 4000rpm so if you use a boost varriable controller from 4000rpm to 6500rpm you get very minamal ALKY control.
With the Snow Performance MAF kit you can controll the ALKY from 3000hz
to 16000hz so even if boost is all finished by 4000rpm you will still get an increase in ALKY flow all the way up the RPM band for better cooling and fueling.
Here's why:
#28
Former Vendor
I still vote FJO, do to the controll factor. But I am bias
With MAP, TPS, RPM nozzle is sweet, 100% duty cycle pump, turn it on and forget about it.
http://www.fjoracing.com/products/waterinjection/
Ricky
Ricky
