Lets Talk Fuel Economy
Old 05-09-2008, 12:44 PM
WJ MARK's Avatar
get the tornado, you'll gain hp and milage, lol. JFWY!
Old 05-09-2008, 12:54 PM
Doobie's Avatar
From following this FI forum it appears to me that the turbos gain more mileage on average than superchargers do. I lost 1 mpg on highway with my Radix.
Old 05-09-2008, 12:58 PM
BigCountryx's Avatar
Gained 1 mpg with radix. Till I dive into it. lol
Old 05-09-2008, 01:13 PM
blownerator
BlownChevy's Avatar
We Documented a 3-4 mpg gain on the Pontiac G8 with the L76. This was an increase from 24mpg to 27-28mpg.
Old 05-09-2008, 01:28 PM
supersub's Avatar
I have seen 3-4 increase with my radix'd 5.3 vs. stock n/a with a conservative tune..
along with moderation of coarse.
Old 05-09-2008, 01:31 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
I know i get better than stock... but i wasn't stock for very long so i really can't say what the gains are.
Old 05-09-2008, 02:46 PM
WJ MARK's Avatar
I thought mine was better stock but now I can't remeber. either way I wish it were alot better since im moving about 38 miles away from work
Old 05-09-2008, 03:45 PM
WorkTruc's Avatar
I Can Get Up To 22 Mpg On Highway,but As Low As 9 Mpg City Because The Radix Is Addictive.
Old 05-13-2008, 07:06 AM
Blown2300's Avatar
One quick question for everyone... are you calculating your MPG at the gas station.. or using your instant/average fuel economy meter in your truck??
I will be the first to call BS when i see a truck go from 13/14 to over 20mpg with just adding boost and driving the same.. no offesne but once you change injectors, your instant meter becomes basically useless.. the error in your fuel injector pulse width vs flow may be off by a few percent.. which in turn throws off your meter.. it doesnt need to be off by much to show a significant difference in mpg
Now if your changing your transmission calibration, stall converter, axle ratio etc to keep the engine spinning slower. The benefit from the boosting system and low engine rpm is intended to offset the friction from spinning the engine faster.. this is where fuel economy comes in. It uses less power to boost at low rpm than it does to spin an engine to high rpm... for example at 6000rpm your engine is using 100hp just to spin.. thats alot of friction!!
Boosting helps mpg.. if you do things to ALLOW it to help mpg.. If you want more mpg, trade that 3.73 for a 3.08, calibrate yoru trans to hold a higher gear, etc..
Boosting > RPM
Old 05-13-2008, 08:06 AM
ZO6Ted's Avatar
Went from 18 hwy to 21-22
Quick Reply: Lets Talk Fuel Economy
