List of stock bottom end and boost pressure?
Old 10-07-2012 | 05:22 PM
GMCtrk's Avatar
I'll be boosting my cam'd stock bottom end LQ9 which currently has 10.5:1 compression (68cc heads). I've kept going back and forth in my mind about whether this compression was too high or not, although the cam I'm running will help bleed off some pressure. E85 gives me some piece of mind. All that said, the main issue is that even with 72cc stock heads, the compression is still 10:1. So, is half a point compression even worth the hassle of swapping heads? I don't think so.
Old 10-07-2012 | 05:23 PM
ak2007r6's Avatar
Stock bottom end with static compression at 10.1:1 running 10-12psi
Old 10-07-2012 | 05:47 PM
chevyboy.520's Avatar
Rebuilding my 5.3, will be running flat top pistons and 317 heads. Compression should be right under 9-1 lol opened up the ring gaps. And will be planning on running 18-20 psi as soon I get a meth kit.
Old 10-07-2012 | 05:48 PM
TXSZ66AVLANCHE's Avatar
Stock bottom end 11.1:1 and no psi
Old 10-07-2012 | 08:10 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I ran 12-14 psi on a stock LQ9 bottom end... I'd say that guy isn't as knowledgeable on these engines as he might think.
Old 10-07-2012 | 08:29 PM
custm2500's Avatar
Ph.D. in HUBRIS
He knows 350s. Clearly doesn't know much about the LS. He was telling me they don't make big power and last. He will be learning soon because like I said he is VERY knowlageble about the old stuff. He is probably already doing his research on here to see what I was talking about. I told him this is the place to fix all his misconceptions about the LS. Here and LS1tech.
Old 10-07-2012 | 08:30 PM
custm2500's Avatar
Ph.D. in HUBRIS
Your sig says custom forged pistons?
Old 10-07-2012 | 08:52 PM
That don't mean he is not using stock crank...
Old 10-07-2012 | 08:58 PM
TRD_Tundra's Avatar
Here in Houston Tellez Motorsports is using a stock bottom end 5.3 running 23#'s of boost on a 88mm turbo. It's best run @ 10.01
https://www.youtube.com/watch?v=B1pj...eature=related
https://www.youtube.com/watch?v=9fK_W_qPcII
Old 10-07-2012 | 09:25 PM
03sierraslt's Avatar
Bottom end is not pistons.
