livernois turbo guys burning plug wires
Old 04-26-2009, 06:47 PM
  #21
Got everything worked out so far. I used a longer LT1 wire for #2 and routed it around and under the manifold. Clears everything no problem with no heat wrap. #6 is still close but I did the same thing going around and under the manifold using a Talor 90 boot on the plug, (they fit alot tighter then MSD) with wrap around the tube and a boot around the wire. So far so good.
Next time i have the manifold off im going to section off the tube on #6 an bring it down with a tighter bend to totaly clear the wire, then the manifold would be perfect regarding wire clearence.
Now i just have to figure out my tune lol
Old 04-27-2009, 09:42 AM
  #22
Truck Sponsor
TrickTurbo's Avatar
Glad you got it worked out. The plug wires could you make them run under your set up and then back around? They will be alot longer but I do not think that will be any problem.
Old 04-27-2009, 10:28 AM
  #23
yep, thats what i did, they were not too long, i think they were both #4 or #3 wires from an LT1 set. Works so far
Old 04-27-2009, 12:19 PM
  #24
GFYS and STFU
Spoolin's Avatar
Good job!! Now post some pics pics pics!!
TAPyvehc93
07-23-2017 10:54 PM
Go5.3tt06
09-12-2015 09:29 AM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: livernois turbo guys burning plug wires
