View Poll Results: LJMS Stage 1 vs Stock48 Triple12
Voters: 35. You may not vote on this poll
#22
Yes with a 4.8 but you're 5.3 there is a difference. I am not the guy to ask though but Rick or Kyle or George, Atomic, Jarrett can chime in lol. I'm sure there is plenty left though just think 600's a stretch without very high boost although more fun driving around. Bigger ar maybe?
#23
Formerly ScreamingL
Example my last setup on 9 psi made 575rwhp on a 5.3
No meth just 93
When turbo flows enough you'll then make more power at lesser boost
#24
I've always said there is no magic to turbo cams. They will all make more then a stock cam, just open up the valve more and longer and let the turbo fill it! I've been running the triple 12 for years and made good power with it. I just swapped out to a 227/227 112 from Jarrett, just cuz I wanted more lope to sound cooler! It feels just as strong on the street, haven't been back to the track yet, but sounds NICE!
As for your turbo size, your gonna be running out of air in the upper RPM's like George said to make much more HP but you can make more torque. Remember, HP is nothing more the torque x RPM. Just short shift it and keep the turbo in it's happy spot and use that torque!
#26
Formerly ScreamingL
#29
We have tested the triple 12 in a turbo 347 with a 76/75 Turbo. 570rwhp on 14 psi
We also had another similar truck with a turbo 347 using an ljms stage 2 turbo cam and a s482/87 made 550 on 9psi
What I can say is the triple 12 will be more fuel efficient for street driving. It has more vacuum at idle and cruising, while the ljms stage 2 cam it was almost at 0 vacuum while cruising.
I think the isky cams are specced more for heavy trucks that do a lot of street driving where as John specs his cams more for drag racing and big hp numbers.
At the end of the day it's personal preference which one you like better.
If you plan to mostly street drive your truck I would recommend the Isky cam but if you are building the truck for Mainly racing go with ljms.
