log manifold help
log manifold help
Since the search function is not working, I didnt search
Im on the fence whether im going to modify a single runner and weld v-bands on to my truck manifolds or of I should just built a log for the drivers side. Im putting an LS motor in my S-10 and the truck manifolds would be a breeze for me if I just modify the primary on the drivers side closest to the firewall to clear the steering. OR... I build a log for it. So im wondering, do you use sched 40 or 80 if you are using butt weld fittings? and do you guys weld the fittings to the header flange and then to standard exhaust tubing on the other side, or do you use schdule "X" fittings into sched "X" pipe into a crossover? What size OD on butt weld fittings? and what size for a merge?Thanks in advnace!
as always, im grateful you are willing to toss out free advice. Wish I could throw some business your way but im yet to step into a full size you have a website of everything you sell?
