Loosing boost at WOT
Old Today | 01:05 PM
xsports33's Avatar
Default Loosing boost at WOT
Hey guys! it's been a long time seen i've been on the forums - life, kids, etc.. i won't bore you with the details.
This just started to happen in the last few months, can't say exactly when since the truck has become my weekend warrior and i don't go wide open very often. I'm losing all boost at WOT and running super rich, it just bogs down. I used to get 7-8 psi at WOT and the truck would pull hard through all gears. Now at partial throttle 50-70% I get around 3-4 psi, but as soon mash the pedal boost drops to 0, FPR goes to 10.0 or lower (bottoms out at 10) and the truck completely bogs down. Happens every time i go WOT from a complete stop or rolling/cruising. I've had the same tune for 5+ years, haven't changed anything. Everything was working cherry up until a few months ago. I replaced the bypass actuator thinking i was loosing boost for that, but no change after replacement. I replaced the belt as well thinking it was belt slip, but same issue after new belt installed.
i doubt its the tune since it's been the same for over 5 years and worked perfectly until recently. i'm thinking something mechanical, i just can't pinpoint it. Any ideas? any help would be appreciated.
Old Today | 01:53 PM
beaner's Avatar
Tcehing In
Giant boost leak. Probably a popped off coupler. Cap off the compressor inlet and pressurize the system with an air compressor if there's nothing obvious visually.
Old Today | 04:16 PM
xsports33's Avatar
thanks for the reply. i need to do a leak test.
but, if it was a big leak why would i make 3-4 psi boost at half throttle and then drop to 0psi at WOT? wouldn't a leak always leak, not just at very high PSI?
89LS1FOXER
06-02-2011 01:15 PM
Blowndenalixl
10-06-2008 10:08 PM
Last Call
05-08-2006 02:27 PM
Holty
04-28-2006 12:01 PM
03sierraslt
09-19-2005 05:24 PM
Quick Reply: Loosing boost at WOT
