lopey turbo cam??
Old 12-22-2011, 01:55 PM
carbongmc's Avatar
PM me your number and I'll text it to you.
Old 12-22-2011, 04:21 PM
blue0453's Avatar
my tr220 with the 112lsa chops good, and the truck seems to run ok. made 486 at 10psi
Old 12-29-2011, 01:05 AM
dirty_old_chevy's Avatar
Originally Posted by stock48
A 212/109 ~110 lsa Isky would chop and work pretty good in a 70mm 12psi 4.8L. The problem with high psi and tight lsa is it can detonate easier.
This intrigues me. Do you know why? I would have thought the egr-effect of more overlap would lessen the chance of detonation. In that case, would it help to run a turbo with a larger hotside and keep backpressure down?
Old 12-30-2011, 10:37 AM
TURBHOE's Avatar
my 215/218 use to chop pretty good. but after i finished up the tune it idles like stock but more girgle to it. if you leave the idle a bit lean it will lope a bit more. so you don't have to have such a huge cam. but at the same time, if you tune it properly most of the lope will go away unless its a bigger cam.
Old 12-30-2011, 11:48 AM
Mod with training wheels
smokeshow's Avatar
Yes it would help. This is the route I am going with on my current build. Little more overlap from higher duration and a giant turbine. Little to be gained on the bottom end but it should make for a nasty combo up top
Old 12-30-2011, 12:13 PM
chevyboy.520's Avatar
When I first turboed the truck I had a 218/224 .600/.605 111lsa cam and it was a very choppy cam, felt good and drove with good maanners. But a lifter took out that cam. So now I have a (stock48) isky triple 12, and it's bad ***. Has a mild lope but it makes more power and drives even better.
This is the 218/224
DSCN0746.mp4
And this is my isky triple 12
cfc50358.mp4
Audio sucks on my phone. But u kinda get the idea
Old 12-30-2011, 12:46 PM
Yeah, thats what I've been thinking also. Leave my 216/220 in 110 cam in my 4.8 and try it with a turbo. N/A it takes off right at about 3000 rpm, so I got a PI 3600 stall when I got my 4l80. 4.8's love to rev, so I can't really see restricting that with a turbo that chokes the exhaust at high rpm. Plus, I really like this cam currently. Its still pulling at 7000, and falls off shortly after that. Ideally, I want to build a system that amplifies what I already have.
Old 12-30-2011, 02:17 PM
Here is a walk around with the triple 12
http://m.youtube.com/index?client=mv...?v=pFR2HDQPahI
Old 12-30-2011, 02:55 PM
slammedsilvy's Avatar
Links don't work, do you know what's up with them? I'm VERY interested in hearing that setup.
Old 12-30-2011, 03:09 PM
jrmchevyman's Avatar
I don't see any links or embedded video at all either on chevyboys posts.
Quick Reply: lopey turbo cam??
