LPE GT2-3 Cam swap info
Old 02-19-2008, 11:52 AM
12SEC SS's Avatar
Default LPE GT2-3 Cam swap info
I've searched, but still have some questions. I've ordered GT2-3 Cam kit with valve springs, and Comp Cam 7.400 pushrods from LPE. Also, the 10% Overdrive balancer from Innovators West with a pin kit and a new crank bolt, and two tools from thunder racing, a spring compressor and the tool to keep lifters up while im pulling the cam out. I have 2.9 pulley on the Radix as well. My only question is:
1. Am I missing something that I should do while im in there? The motor has 10k miles on it, and its a '03 LQ9
Thanx
Old 02-19-2008, 01:13 PM
TravisH's Avatar
Dont forget your gaskets!
-water pump
-front cover
-crank seal
-valve covers(optional)
Old 02-19-2008, 03:40 PM
brobradh77's Avatar
injectors?? what size you running? I know with my GT2-3 and Radix I was over maxed out on the Radix 42#'s and had to jumo uo to 60#'ers
Old 02-19-2008, 04:14 PM
12SEC SS's Avatar
Interesting, what diameter pulleys are you running? I have 2.9 Radix, and will have 10% Overdrive crank that I will put on at the same time as the cam..
Old 02-19-2008, 05:41 PM
brobradh77's Avatar
I maxed out with a 3" pulley and am now running a 2.8"
Old 02-19-2008, 05:42 PM
supersub's Avatar
you will run out of injectors with the set up described.
Old 02-19-2008, 07:25 PM
02RedHawk's Avatar
If those are stock heads, the optimal PR length is 7.425", although you can still get away with 7.400" - you'll just have a little less lifter preload.
Old 02-19-2008, 07:27 PM
12SEC SS's Avatar
Can you point me to part#/where I can buy 60lb injectors? The ones I have now are 42lb and they are what came with the Radix
Old 02-19-2008, 07:43 PM
supersub's Avatar
EV1 or EV6 type connectors,I believe you have the EV1 type if so you can order them thru Joe over @ left coast 32,look to your right>>>>>>
Ray
Old 02-19-2008, 10:45 PM
blownerator
BlownChevy's Avatar
I used these, got them from summit and retrofitted my stock harness with them.
15.99 plus shipping.
Quick Reply: LPE GT2-3 Cam swap info
