LPE GT2-3 Cam swap info
I spoke to Joe, he suggested that I stick with the 42s. I run a return-fuel system, with boost pressing on the regulator, the fuel pressure raises 1:1, Ive convifirmed this with a fuel pressure gauge, boost gauge, and shop's air compressor
So at this higher pressure the injectors should keep up...I'll let you all know after the dyno sometime next month i hope
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
So at this higher pressure the injectors should keep up...I'll let you all know after the dyno sometime next month i hope ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
What fuel pressure you gonna be running at WOT?...62ish? I'll bet you will not only be out of injector (over 100%IDC) but also have a hard time establishing a flat AFR (11.5-12.0) through a 3rd gear pull to red-line. All JMO of course
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
gtyler04
07-28-2015 06:21 PM
