LPE GT2-3 Cam swap info
Old 02-24-2008, 08:46 PM
12SEC SS's Avatar
I spoke to Joe, he suggested that I stick with the 42s. I run a return-fuel system, with boost pressing on the regulator, the fuel pressure raises 1:1, Ive convifirmed this with a fuel pressure gauge, boost gauge, and shop's air compressor So at this higher pressure the injectors should keep up...I'll let you all know after the dyno sometime next month i hope
Old 02-25-2008, 08:29 AM
krambo's Avatar
What fuel pressure you gonna be running at WOT?...62ish? I'll bet you will not only be out of injector (over 100%IDC) but also have a hard time establishing a flat AFR (11.5-12.0) through a 3rd gear pull to red-line. All JMO of course
Old 02-25-2008, 08:35 AM
12SEC SS's Avatar
My WOT pressure is 68-70 ish..
Old 02-25-2008, 09:03 AM
krambo's Avatar
You running an aftermarket FPR? I still stand by my "you will be out of injector" statement.
I checked out your website. Nice work. I hope it performs well for the amount of time you put into her!
Old 02-25-2008, 10:11 AM
12SEC SS's Avatar
Thanks, time will tell As it is now, its making as much power as the 383 LT1 was making on juice, and between me selling the stroker, buying the new setup, and doing most the work myself, it didnt set me back very far either $$ wise. I'll let you guys know how I make out on the dyno. LPE has springs on backorder and they didnt ship the cam yet
Bumpers
11
03-04-2024 05:55 PM
OHsixLS3
12-27-2016 09:30 AM
gtyler04
07-28-2015 06:21 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: LPE GT2-3 Cam swap info
