LQ4 swap complete
Old 09-30-2008, 08:43 PM
  #21
kbracing96's Avatar
Originally Posted by 2ktransam
That's not good to hear. I was hoping that my 60e would hold. Perfomabuilt thinks it will but there not sure because it's a heavy truck. What broke in your trans?
I don't know yet, haven't pulled it. Was doing a boosted launch, got to 8psi and BOOM! No forward gears, only reverse.
Old 09-30-2008, 09:23 PM
  #22
bud8fan's Avatar
wow...sorry to hear that kyle...glad i went with the 80e..
Old 09-30-2008, 09:55 PM
  #23
2ktransam's Avatar
How much do you guys have in your 80e setups? From what I am seeing it looks like $5k swap if not more. I deffinitely can't afford that right now so I'm getting scared.
Old 09-30-2008, 10:00 PM
  #24
kbracing96's Avatar
2wd guys have it easy, us 4wd guys it's a PIA. I think I'm gona go with a used tranny and shift kit. Might try rebuilding it myself, but still looking into it...
Old 09-30-2008, 10:25 PM
  #25
bud8fan's Avatar
around $3500 after its all said and done....
Old 09-30-2008, 10:31 PM
  #26
2ktransam's Avatar
Where did you get your trans? What are the specs on it?
Old 10-09-2008, 04:14 PM
  #27
yeah kb... they are both electric pumps, but I know how much gas I have. Fuel pumps generally seem to last a lot longer being that they don't live in a corrosive liquid all of the time, and when you truck runs outta gas it stalls the motor completely not causing a buch of knock and detonation right?
Old 10-09-2008, 10:43 PM
  #28
quicksilverado's Avatar
I used a stock 80e and it ran about 1700.00 including a 2800 Art Carr tq. converter.
I ran 12 psi through a 370 with 42 lb injectors and meth. It made about 600 to the ground.
Old 10-10-2008, 08:11 AM
  #29
zippy's Avatar
Originally Posted by kbracing96
And what happens when your fuel pump goes out?? About the same odds.... Both are electric motors driven pumps...
Sound like it's a BEAST!!
If the fuel pump dies you aren't likely spraying enough meth to keep it running. It should stall. If the meth quits you'll likely just run lean and detonate to a cracked piston.
Bluecollar Hotrods
06-11-2024 11:37 PM
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
iregret
07-27-2015 10:32 PM
NuckenFuts
07-09-2015 08:45 AM
Quick Reply: LQ4 swap complete
