LQ9 with Radix issues
Originally Posted by Brian@JPA
its almost impossible to plug those in the wrong way.
This is my 3rd Radix install but first with the return fuel system.
blownerator
Originally Posted by TurboGibbs
Ok, factory quick connects have a 3/8" line and a 5/16" line. The quick connects on the fuel press block had 3/8" male fittings on both. We had to temporarily rig the return but had to guess at which one the pressure was supposed to go on. Follow me?
then someone messed with the fuel rail adapter (fuel block). I have one sitting right in front of me, and they are 3/8 and 5/16 on the adapter. If you need a new adapter let me know.
Is the inboard (supercharger side) the larger or smaller fitting?
He did all the swap of the regualtor stuff. I'll have him look into it.
I just thought of something, The fuel pressure regulator block came with 3/8" quick connects for both the supply and return. Well, the return is 5/16". So temporarily we had to rig a hose using part of the factory rail until he can get a 5/16" quick connect fitting from magnasun. We did our best guess to which side was the supply and return...Those could be swapped but the pressure responds to boost and vacume as it should since it is referenced off the intake. Can someone varify which side is the pressure and return?
d
blownerator
He had to get all the 03 model stuff from Maggie since the kit was off a 06. The adapter block is new. It had a wrong fitting in it from Maggie is my understanding.
The 3/8 (feed) is on the outside of the rail adapter and the 5/16 (return) is on the inside.
