LS9 Cam -
LS9 Cam -
Well I finally blew the engine after 100000 miles of 15 lbs boost everyday for 6 years and have ordered an LS9 cam for a new engine build. Does anyone know if the LQ4 Blocks have the provisions for the timing chain damper and do I need one? Your help would be much appreciated.
The lifters got pooched and looking back now it made sense. I put in the Com 918 springs which increased the load by at least 50lbs at full valve opening and I should have also changed the lifters to the comp cam ones. Eventually all the lifters collapsed and I found needle bearings in the oil. Had the lifters held up there is no doubt in my mind that I could have gotten 150000 miles.
I am picking up a new LQ4 tomorrow and retrofitting the motor with the LS9 cam and LS9springs. I considered the LPE GT9 cam which will need comp springs for sure but elected for some fuel economy since it is a daily driver. The dyno chart on the LS9 seems to pull very hard past 6600. The LSA should allow me to idle at 500.
Im also considering a powerbond pulley to get some extra boost while the motor is out.
Also I found out the LQ4 blocks do not have the provision for the chain dampener. I will be relocating the cam sensor to the front cover so we'll have to see how that pans out.
Lpe has a cam sensor relocation kit. Lq4 blocks have untapped bosses but the chain dampener for the ls1 is different than ls2. I was going to run the ls9 cam but have changed direction. I'll be interested to see your results.
