LSX 427 L92 MP122HH Front Inlet Truck setup
#162
WOW , great burb !!!!!! and sweet build up !!
just curious why not add a 2nd fuel pump ? seams a safer way to go
sorry to hear about your son , and good to hear your son is doing alot better
#163
The plan is to add to the fuel system as needed. We were unsure of fuel pressures that is why he added the gauges. He has all the flexfuel system so we are seeing how far it will go before an upgrade is needed. We may need to drop his boost a little until we have everything finished.
#164
I agree with that idea. Adding a fuel system as needed would be nice. That way you know how far you can push the stock pump. If you don't do it that way and the secondary pump fails without you knowing you could run it lean quickly. You're best off pushing the single pump to it's limits of flow, dialing everything in, then adding the second pump just to take some stress off of the stock pump. The flex fuel pumps are big volume to start with so he will likely be fine anyway.
#165
amazing truck! congrats on getting her running. i am jealous of how understanding your family is with your truck hobby. mine isnt as much. i hope your son has a speedy and full recovery.
#167
well guy's the boost numbers are in!****** 14 psi******* 80% throttle did not even hit 6000rpm. afr was rich,boost actually hit 15 psi but had to let off due to traffic ahead.
the whole run was started rollin thru second softly and then increasing trottle watching boost #'s along with fuel pressure and afr,thru some additional tuning a
Wot to come soon enough....
never figured a 3 ton rig to plant you in the seat and sway side to side.
Any body want a ride!
BTW! what a wonderfull sound WEEEEEEEEEEEEEEEEEEEEEeeeeeeeeeeeeeeee!
go Maggie!
go Maggie!
#168
go Maggie!
go Maggie!
