LSX 427 L92 MP122HH Front Inlet Truck setup
Old 07-10-2008, 09:50 PM
  #161
FormerVendor
leftcoast32's Avatar
Very Cool! The Grafix turned out like a factory application!! Love the gauges too!!
Old 07-11-2008, 12:40 AM
  #162
s/c'd cav's Avatar
WOW , great burb !!!!!! and sweet build up !!
just curious why not add a 2nd fuel pump ? seams a safer way to go
sorry to hear about your son , and good to hear your son is doing alot better
Old 07-11-2008, 08:06 AM
  #163
FormerVendor
The plan is to add to the fuel system as needed. We were unsure of fuel pressures that is why he added the gauges. He has all the flexfuel system so we are seeing how far it will go before an upgrade is needed. We may need to drop his boost a little until we have everything finished.
Old 07-11-2008, 08:58 AM
  #164
zippy's Avatar
I agree with that idea. Adding a fuel system as needed would be nice. That way you know how far you can push the stock pump. If you don't do it that way and the secondary pump fails without you knowing you could run it lean quickly. You're best off pushing the single pump to it's limits of flow, dialing everything in, then adding the second pump just to take some stress off of the stock pump. The flex fuel pumps are big volume to start with so he will likely be fine anyway.
Old 07-11-2008, 09:42 PM
  #165
amazing truck! congrats on getting her running. i am jealous of how understanding your family is with your truck hobby. mine isnt as much. i hope your son has a speedy and full recovery.
Old 07-12-2008, 09:38 AM
  #166
blown3qtr's Avatar
Decals look AWESOME! and again that is one sick sub!
Old 07-17-2008, 07:31 PM
  #167
supersub's Avatar
well guy's the boost numbers are in!****** 14 psi******* 80% throttle did not even hit 6000rpm. afr was rich,boost actually hit 15 psi but had to let off due to traffic ahead.
the whole run was started rollin thru second softly and then increasing trottle watching boost #'s along with fuel pressure and afr,thru some additional tuning a
Wot to come soon enough....
never figured a 3 ton rig to plant you in the seat and sway side to side.
Any body want a ride!
BTW! what a wonderfull sound WEEEEEEEEEEEEEEEEEEEEEeeeeeeeeeeeeeeee!
go Maggie!
Old 07-17-2008, 07:42 PM
  #168
FormerVendor
go Maggie!
That's what I am talking about!!!
Old 07-17-2008, 07:44 PM
  #169
Destroyer of Transmissions
1SlowHoe's Avatar
Drive by video, get it now
Old 07-17-2008, 07:50 PM
  #170
GFYS and STFU
Spoolin's Avatar
Fug it...BAN HIM NOW!!! I'm getting blue ballz here!
Quick Reply: LSX 427 L92 MP122HH Front Inlet Truck setup
