LSX 427 L92 MP122HH Front Inlet Truck setup
#32
Man....I'm liki'n this more every time I see it! Some observations/questions:
Looks like the coolant lines for the intercooler have to be re-routed to complement the different placement in this set-up. I know none of your stuff is mounted, yet, so you don't have to "move anything", you can place everything where ever you need. Maybe the reservoir over in the "2nd battery location" under the pass hood hinge.
What is that waterpump off of? It looks like it has the ability to have a swivel on the outlet
#33
#34
Yes the coolant lines are different than the original radix truck set-up but will work out quite well under the hood of these trucks.
This set up should provide a lot of future mods along the way. As you said above yes a "grippy" tank could be added,along with the possibilities of many others.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#36
These lsx blocks have some fitment issues of there own i tell ya! when installing the A/C bracket i noticed it was not fitting square onto the mounting flanges only to find out the additional head bolt bosses interfere.And the only way to fix it is to remove the material from the a/c bracket. So for those of you building the LSX block beware...
![](https://i64.photobucket.com/albums/h179/ssupersub/CIMG9999.jpg)
![](https://i64.photobucket.com/albums/h179/ssupersub/CIMG9998.jpg)
