Ly6 turbo compression ratio help
Old 10-18-2015, 06:05 PM
Restricted
JordanH's Avatar
Default Ly6 turbo compression ratio help
I'm in the middle of building a ly6 for the Tahoe, long story short I got a great deal on some forged mahle -26cc dished Pistons and I'm having a little trouble figuring out a good CR to be at... Here's a rundown of everything:
-26cc dished Pistons made for stock ls 3.622 stroke and .927 pins
Piston compression height: 1.314
Block deck height (stock): 9.240
823 heads: 70cc combustion chamber
Ls9 head gaskets 0.051 thickness
And whatever length rods I'm gonna use...
Here's the problem.....
6.100 rods give me -0.015 below the deck, which = 7.83:1 CR
6.125 rods give me +0.010 above the deck, which = 8.17:1 CR
6.200 rods give me +0.085 above the deck, which = 9.42:1 CR
I could use a little thinner head gasket 0.041 to bring compression up some... On the 6.200 rods and 0.041 gasket I would be at 9.62:1 CR.. I'm guessing this would be my best bet? Some input would be appreciated! Also, would the piston sticking above the deck on the 6.125 and 6.200 rods be a problem?
Old 10-18-2015, 07:42 PM
Formerly ScreamingL
George C....'s Avatar
Personally would not use that brand piston for boost
Old 10-18-2015, 09:23 PM
Restricted
JordanH's Avatar
Why is that?
Old 10-18-2015, 09:28 PM
Formerly ScreamingL
Not fan of them with boost
Old 10-18-2015, 09:38 PM
Restricted
JordanH's Avatar
Okay... Well what do you think about 9.5:1 CR for my truck? Think it would be decent?
Old 10-18-2015, 10:00 PM
Formerly ScreamingL
9.5 is a very good SCR to have for an over all performer
Gives you room for 93
Still close enough for e85
Still gives you off boost power
Old 10-18-2015, 11:12 PM
Vortec350ss's Avatar
just gonna toss this out there... 6.2" rods put the piston above the cyl head height. its impossible. Look at your deck height and gasket thickness... What you will need to do is mill the heads down, but it seems you're kind of out of luck on this one. Thats a VERY big dish for stockish cubes.
Old 10-18-2015, 11:18 PM
with a 6.125 rod and .041 gaskets with a milled 243 that comes in at a 60cc chamber you can achieve a 9.0 compression. that is very acceptable. A little low for my liking... but very doable. For reference, the LSA, LS9, and LSx376 are all that same compression
Old 10-19-2015, 12:03 AM
Formerly ScreamingL
Milling the heads kinda goes against whole strength in deck thickness
Spending money to save money on cheap stuff
By time you figure out a way to make those pistons work you would of been better off with a set of diamonds or wiseco
Old 10-19-2015, 12:12 AM
Restricted
JordanH's Avatar
Yeah.... That's what I figured.
Quick Reply: Ly6 turbo compression ratio help
