Ly6 turbo compression ratio help
Old 10-19-2015, 12:13 AM
Vortec350ss's Avatar
I gotta agree with George here... it will take some serious work around to make these work the way you want.
I don't think milling the heads to get to 60cc will cause you any problems, but they will become weaker for real extreme boost and power. Get yourself some wiseco -11's or something and call it a day. Can you sell the pistons for more than you are into them for?
Old 10-19-2015, 12:14 AM
Restricted
JordanH's Avatar
I'm prolly just gonna buy a set of wiseco 4.030 -9cc or -11cc .945 pistons and call it a day... Run them with a set of genIV rods and arp bolts...
Old 10-19-2015, 12:18 AM
Restricted
JordanH's Avatar
I'm pretty sure I wouldn't have a problem getting what I have in them back... I think they're at a real good price
Old 10-19-2015, 12:31 AM
Restricted
JordanH's Avatar
I'm also gonna need a cam spec'd for this motor.... Uhh uuhhhmm, Vortec350ss! You seem to be pretty knowledgable in that area.
Old 10-19-2015, 04:57 AM
Gadgetized's Avatar
Do you not have the rotating assembly? If you were limiting yourself with stock rods, a stock piston is fine. I'm building a stock LY6 now with gapped rings. It should be plenty strong for what I want to do. What are your power goals?
Old 10-19-2015, 12:55 PM
Restricted
JordanH's Avatar
Yes I do, but I have to bore it at least 0.010 over to clean up one of the cylinders.. I'm just wanting to see around 7-8 at the wheels. Does a company make stock Pistons .010, .020, or .030 over?
Old 10-19-2015, 01:01 PM
10 Second Truck Club
RS/SS 4.8's Avatar
Open that sucker up .030 and put some forged wiseco pistons with forged scat rods and be done with it like i did on mine. My 370 with 70cc heads is at 9.8CR.
Old 10-19-2015, 01:39 PM
Restricted
JordanH's Avatar
This is more than likely what I'm gonna end up doing... Might as well spend a few hundred more and put some nice rods in it too! I think I'm gonna do the 80e swap and keep the 5.3 in there for a little longer, until I get done with the ly6
$A_Money$81
03-27-2023 10:25 AM
mhorn0817
01-26-2022 08:48 AM
Slammed silverado
09-28-2015 06:14 PM
Quick Reply: Ly6 turbo compression ratio help
