Lyscholm Vs MagnaCharger
Old 04-28-2006, 08:52 PM
  #31
02sierraz71_5.3's Avatar
Originally Posted by moregrip
side by side:
MP122............................................. .................................................. .......Lysholm
with my 3k stall I never see below 4k rpms except for part of the 60ft, Id expect the lysholm blower to be at least .3sec faster in the 1/4. At 20 higher iat's its making around 25more hp and 30 more tq @ 4k rpms. I definately think the 122 is more efficent especially to be able to compete against a blower with around 20% more capacity but in the end its about who is faster.
my .02
thanks for the info
Old 04-28-2006, 09:03 PM
  #32
what a rush!
moregrip's Avatar
my .02
thanks for the info
I expected a response like this
under WOT or near WOT I agree, however, I find myself at partial boost and something less than WOT far more often then the condition you described above.
Old 04-28-2006, 09:11 PM
  #33
under WOT or near WOT I agree, however, I find myself at partial boost and something less than WOT far more often than the condition you described above.
Glad I could oblige,
for a daily that will see stop and go everyday and needs reliability Id go with a magna hands down
Old 04-28-2006, 09:12 PM
  #34
what a rush!
moregrip's Avatar
Old 04-28-2006, 09:18 PM
  #35
I'd like to see the same comparison on a LS2 6.0 with it's better breathing heads.That would give a better idea of the potential of both superchargers.My guess is that the 122H will be targeted at Vette owners first.
Old 04-28-2006, 10:05 PM
  #36
BigTex's Avatar
As I said early in this post, you really can't outright compare 10psi of boost between the two unless EVERYTHING is identical. That means the better designed Radix J tube will skew the results when compared to the whipples crappy 90* bend inlet.
With the better intake, the Radix isn't fighting a restriction and will make more psi with out overspinning the blower (less heat). The whipple will have to spin more rpms to compensate for the crappy intake to produce 10psi, therefore generating more heat.
Which blower has less parasitic loss?
Old 04-28-2006, 10:22 PM
  #37
MNC5's Avatar
Nice graphs... I called three weeks ago and was told it might be ready for delivery by December or later. Is the 122 a bolt on replacement for the 112?
Old 04-28-2006, 11:36 PM
  #38
What I heard was,that the housing and rotors were about an inch longer than the m112 and everything else was the same.It would move the J-tube an inch closer to the firewall.
Old 04-28-2006, 11:37 PM
  #39
jephs422's Avatar
The ONLY thing changed was the compressor during this test. direct inlet's eliminated the change in restrictions between 2 different types of "j-tubes"
Old 04-29-2006, 10:09 AM
  #40
BigTex's Avatar
Great, thanks for the post jephs422. Thats more like it.
Quick Reply: Lyscholm Vs MagnaCharger
