Lyscholm Vs MagnaCharger
#42
Hmmm... so much for Whipple's claim that their "superior" twin-screw design does not need an intercooler. Thanks for the information, Brian. This is invaluable.
#43
what a rush!
Originally Posted by BlownChevy
More info for you Richard. Please note that the "oil out" channel is actually discharge temps. What you have to remember: This is proving the Screw companies past claims of 80-100* less in discharge temps.
for some reason these kinds of graphs are always easier for me to comprehend, damn good data, and quite honestly, I am surprised the lysholm ran so hot.
any plans for an autorotor?
#44
Former Moderator :(
I like the fact that 10 lbs of whipple boost and 10 lb of Magna Charger boost produce identical HP and torque numbers at 6400 rpm and the Magna Charger is a 2.0 and the whipple is a 2.3. even the difference in heat did not seem to affect the numbers. I also know this would be a whole different ball game on a 427 with 15 lbs of boost but for a every day street vehicle on pump gas and 10 lbs of boost or less the Magna Charger really shines
#45
what a rush!
that new 122 is an efficient bastard! you Magnuson boys sure know how to keep a guy broke
BTW Dummy, thanks for all your hard work, as always you are a huge part of what gets done around there, sort of the man behind the scenes
#47
Correct, however with the lower discharge temps more timing could be added .
This test was preformed to prove or disprove the claims of lower discharge temps.
#49
It was in an article about the Shelby GT500 powertrain and had a detail about the Eaton R122H. Basically went over how much it was an improvement over the previous design. It did particularly mention that it was a hybrid between the current and an upcoming design. There is nothing about this on the internet that I have found yet. I have the article and I'll scan it if I can find it.
#50
what a rush!
