maf or sd
maf or sd
hey i need advice i wanted to know if my stock maf will handle 10lb of boost on a stock 6.0 wth upgraded heads? also i think i need to replace my maf does anyone have one preferable close to san diego, ca.?
Save your money. Your tuner can make your stock MAF work just fine at 10lbs. Just make sure you are running a 2 bar MAP. I've been running a stock MAF and a 2 bar at 10lbs for almost 4 years without a single problem.
Rick
Rick
When you are ready to get tuned, bring along a Delphi 2 bar - GM# 12615136 to swap out (plug n play) for your stock 1 bar MAP. Just unplug the 1-bar MAP on top of your intake and swap them out. The Tuner has to adjust the tune to recognize the new MAP readings. Then you can keep you MAF and you won't have to add a AIT sensor.
Rick
Rick
This below, is the sensor we use for a 2-Bar OS tune, the harness plugs right in and everything is plug and play...I have been using this sensor for a year in my SD tune and it works flawlessly! I am still going to use it, but adding an LS7 MAF back into the system for smog purposes...
12615136 - 2007+ LNF (turbo) Cobalt/HHR SS, Sky Redline, Ion Redline, Solstice GXP Barometric Sensor...
