Maggie and Nitrous - Stepped PSI?
Old 03-23-2009, 10:50 PM
1Bear's Avatar
Roger, mine has allway's done the same thing. Mine won't hold the boost though. Right after each shift, the boost level will go up about a pound to a pound and a half, then slowly come back down to normal as I run out that gear. Of course when I say slowly, nothing is really happening very slow, but it doesn't just instantly go up and fall off either.
Old 03-24-2009, 07:03 AM
KySilverado's Avatar
Yeah that's the scenario I saw with the 60e. Boost peaks right after the shifts then dropping off. My guess is its the 80e and its rotational mass keeping the motor under load through out the gear, coupled with nitrous keeping the PSI higher.
Not a major deal just curious about it and wondering if it was telling me something like my exhaust is restrictive or its time for new heads or a cam or something.
Old 03-24-2009, 11:37 AM
FormerVendor
leftcoast32's Avatar
As the size of the shot increases the boost spike will also increase to a certain point. We have seen a 4-5 psi boost spike during the spray with a 150+ shot through the MagnaCharger.
Old 03-24-2009, 12:17 PM
Midnightrider's Avatar
Roger im surprised you have put up with that heat pump for this long. I just got rid of mine due to i was tired of seeing 125* IAT just cruising. I went twins. One thing ive seen some trucks doing is making a bigger resevoir for the coolant. This keeping the over all circulating fluid cooler
Old 03-24-2009, 12:24 PM
Moderately Differentiated
dewmanshu's Avatar
Run the 1320 without nitrous and report back with scan!
I saw the same thing roger as your scan, but I certainly don't "remember" the extent of gain compared to what you received in boost. I will pull my scan from my 11.35 run to see what the boost increases. I was shooting 75shot form the hole fww. Also, I would certainly bring up(agree with others) the point of nitrous and cylinder pressure under load. Then add in all the smaller variables that have changed with the 80e, like rotating mass, lower rpm into next gear, yaddy yaddy.
Old 03-24-2009, 05:20 PM
150+ Think I'll save that for a forged motor and couple stiff drinks.
Man if I had the coin my grilling days would be over. In the mean time I'll push what I have to its limits. I've seen some of the Cobra guys do that. Special tank that you can drain, fill it with ice and pump it through the blower to cool it and the engine down in the pits and ice it up before a pass. It really isn't that it heats it so much through the pass its what you start with (heat soak) and where it ends up.
Who the heck wants to make a pass without the gas. It's so damn disappointing after you've been introduced to the stuff. I'm confident its load dependent now. I remember back in the day when I was SD tuning, pulling a trailer up a hill and saw 11 psi in the log.
Old 03-24-2009, 05:24 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Originally Posted by KySilverado
Who the heck wants to make a pass without the gas???. It's so damn disappointing after you've been introduced to the stuff. I'm confident its load dependent now. I remember back in the day when I was SD tuning, pulling a trailer up a hill and saw 11 psi in the log.
lol, yeah I ask myself the same thing
Old 03-24-2009, 09:16 PM
dewmanshu's Avatar
yeah yeah yeah...
Alright, mine is no where as severe as yours. I had a ton of good cold air that day. I was spinning all 4 out of the 60'. On this run it dead hooked. Never mind the leaning out and rev limiter shutting fuel off...I am working on that as we type. (voltage...sigh)
kpa/boost rpm Gear
161.9(8.78) 3897 1st
161.9(8.78) 6446 1st
168.1(9.68) 5028 2nd
164.2(9.12) 5711 2nd
166.6(9.46) 6547 2nd
172.8(10.36) 5160 3rd
173.6(10.48) 5144 3rd
*at beginning of my run my IAT was 104* and at the end it was 151*.
Old 03-24-2009, 09:36 PM
Similar log. So the higher the load with gas and a maggie the higher the boost.
About the same climb in IAT's.
Good thing you had some race gas in that thing.... 23* timing and you're at a dip. 25* for most of that pass? The low timing in mine is what kept me from running a couple of strong runs Saturday.
Old 03-24-2009, 10:06 PM
brobradh77's Avatar
dayum look at the timing
simman22
01-21-2017 10:27 PM
gavin2005
09-13-2015 09:04 PM
gmcyukon
09-07-2015 08:46 PM
06murder
09-04-2015 03:54 PM
hackrst
09-02-2015 05:27 PM
Quick Reply: Maggie and Nitrous - Stepped PSI?
