Magna Charger TVS 1900 Is INSTALLED and running UNREAL
#141
Blownchevy: Is there an optimal CR for the TVS 1900? I am getting ready to order my stroker kit and wanted to get some input. I also just learned that the 420 stroker kit is available, you stated that the 1900 can handle up to 800HP do you have any input on which stroker setup would be better? The truck will be a daily driver and I am at altitude (5000) ft.
#142
The 2300 would be better suited to do it. However the 1900 or 122 could do it.
I am a believer in keep the CR up, with todays tuning software its easy to make things work well together. I would not go lower than 9.2:1.
#143
So, my forged 6.0l with stage II heads, blower cam, and 9.3:1 cr, that I am getting a 1900 for is going to be just about perfect. Awsome!
I think I will wait a couple months, or so, to see if there are any bugs to be worked out before I get mine, but this is what I built it for. I'm glad to hear that it is living up to all the hype I've been reading for so long. Good work.
#144
Blownchevy: Will the 2300 be out about the same time at the 1900? Based upon the input here I may just go ***** out. Thanks for the help. I am now just patiently waiting for the manifold and 2300. I guess I'll keep researching the 6L90 swap while I wait.
#146
any kit for the NEW body style 5.3? i'm trying to pick a kit for my truck. 07 sierra 5.3 (flex fuel if that matters, never run it) 4" lift and 35s. looking for more overall power and some low end for towing, 2-3rpm range probably.
#150
I don't think he blew the engine, but the tranny did finally go.
https://www.performancetrucks.net/fo...d.php?t=412818
