Magna Charger Vs Pro Charger
#31
Originally Posted by zippy
I'd be interested in seeing what the Procharger did at peak power since it didn't reach that by shutdown rpm. Either way I'm a fan of both blower units, where the difference is going to come in is at the track. The IAT's of the radix by 1/8 track are going to be making the difference in power over the procharger. On the street it's going to be a toss up with the radix having an advantage in stoplight racing. I'm curious though, with the comparison why wasn't a P-1SC used with only a 325 cube engine?
Retest! You know we are never satisfied!
#33
I agree, the only difference that could make more power at the same boost would either be from a difference in the air temperature going in or a difference in parasitic drag. (assuming the tuning is equall on both). For a daily driven street truck it'll be tough to top the Maggie.
#34
I'd stick with the maggie as well and the differences I was refering to that MAY give more power with the P1SC could be IAT's or drag etc not from the actual boost press. I'm just trying to stay open minded. But we won't know until someone tests it. I was really pushing that I speculate the lower to mid hp & tq #'s would be better with the smaller P1SC vs the D1SC on that small of an engine.
#38
Adkoonerstrator
When I used to run a procharger on my car I followed them pretty close. The D1SC guys always made more boost and faster(started at lower rpm) then the P1SC guys. Procharger advertising always mentioned the P1SC as better for midrange but, in the real world that never seemed like the case.
IMHO the P1SC wouldn't have faired as well as the D1SC in this test. It would have to spin faster to produce the same CFM as the D1SC which would mean more heat and drag.
#39
Something I'm interested in here. I happen to be working on an SSS at the moment with a D1SC. It has a 4" pulley. From about 2700rpm to 5000rpm it only has 5psi and from about 5200rpm to 5800rpm (shift point) it rises to 8psi. Do you have a printout of the boost level during the dyno run?
#40
Tribe Shaman
that's something that is disturbing me too.
it is the low boost under 5000 rpm's.
my powerdyne does not flow like a D-1, hell the D-1 has a flow rate of 1400 cfm's.
but my powerdyne produces a higher boost number then the D-1 according to the chart provided.
from 2000 to 6500 my unit produces 1.5 to 1.8 more psi at the same rpm.
what is baffling me is that the D-1 is a far better head unit then what I have.
did it have a small leak that bleed off, was it the intercooler that caused a pressure drop.
granted I know powerdyne's. I'm running stronger bearings, I have polished the inside of the scroll for less resistance, I shimmed my impeller blade closer to the scroll for a tighter tolerance, I am running a stronger aftermarket belt, but I still can not no where near flow like a D-1.
