MagnaCharged 122HH TBSS at 15 PSI of Boost
#21
FormerVendor
I think the velocity of air across the sensors changed greatly when I descreened it and installed the 4" intake. My readings at the time went from the 440's to the 370's (g/sec) with that change alone. I also need to run some logs and see where it is hitting and to see if it is maxed out already and where, I will keep all posted. I will be installing the 100mm MAF in the next week or two and will post up the changes.
#27
Adkoonerstrator
What is happening on his setup is similiar to what some guys were doing adding resistors to the MAF to lower the reported airflow. I think Parish even tried this a while back. By reporting lower airflow values to the computer you can stay within the 512g/s limit, just have to adjust fuel/timing accordingly.
#30
FormerVendor
The 07 TrailBlazer SS uses the (2) low and high frequency table for the MAF where as the '06 and older trucks have the single MAF table. I am sure that this has something to do with it also.
