Magnacharger/nitrous SPRAY PICS
Old 11-13-2006 | 05:44 PM
NXRICKY's Avatar
Former Vendor
Originally Posted by 1SlowHoe
Thats me
So I get the felling you want one .
Old 11-13-2006 | 05:54 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Not me.....
Question 1: How do I tune for this since the MAF will be removed from the process? I would need to run less timing I assume with say 10psi and 50 shot than if it was just the 10psi. I know with the MAF and a dry shot the MAF takes care of the fueling but with a wet shot after the MAF how do I adjust timing? 2 tunes?
Question 2: Can I install the plate and plug the ports until I get the nitrous system installed? Or do I have to do it all at once?
Question 3: Do you take Paypal?
Old 11-13-2006 | 06:17 PM
NXRICKY's Avatar
Former Vendor
Not me.....
Ok
1 The nitrous system is standalone. With that said, it will make you IAT colder. You will be suppling the fuel with the nitrous system. I will need to know base abnd final psi, and if the regulator is boost reference or not. This will set up the jstting. You will need to monitor air fuel, the nitrous may cause your boost to go up, and not sure what that will do to your tune.
2. YES, adsolutely.
3. maybe
Ricky
Old 11-13-2006 | 06:47 PM
wkdivr's Avatar
This same system will work with meth, too, right?
Old 11-13-2006 | 08:13 PM
04Denali's Avatar
I know absolutely nothing about tuning so somebody will need to explain a little more about what I am trying to say. A simular question was asked a while back about spraying post blower, When spraying your AIT temps will go to something like below 30* I can't remember exactly what was said, but in you tune you can pull timing when AIT hit a certain Temp, just like when the PCM pulls timing when you AIT get to hot.
Hope that helps.
Mark
Old 11-13-2006 | 09:30 PM
1SlowHoe's Avatar
Hmmm. That would be a good solution since I would never see temps that low unless I was spraying.
Old 11-13-2006 | 09:50 PM
thunder550's Avatar
High on diesel fumes
Any idea when production units will be available for sale? Any idea on price range yet?
Old 11-13-2006 | 10:15 PM
1SlowHoe's Avatar
See post #7
Old 11-13-2006 | 10:17 PM
thunder550's Avatar
See post #7
DOH!!!
Missed that one somehow. Thanks.
Old 11-14-2006 | 04:47 PM
GoatChs's Avatar
It will raise the blower top half up .280.
Injector height issue could not resolved prior to me having to ship the blow back to its owners.
Stocker type injectors will need there fuel rail modified to fit.
Ricky
Ricky, What if you made the thickness of the plate the same height as the delta between the truck multec injector and the car injector height? Seems that would make it simple for us to just swap to the taller injector and solve the issue?
