Magnacharger - Normal Driving
#31
How do I change this text
I'm with Trever1t,
one step at a time, you may find that you don't wand/ need a new torque converter ( I like my stock one). and yes you are right the 80 will be much happier than the junk 60. I would get a shift kit, along with the radix. And enjoy. Then see what you need/want next....
AND FWIW. I bought on of those high-end B&M coolers only to have the bypass valve fail and the cooler plug. it nearly took the trans with it. IMHO, the stock one will do just fine, especial with a stock converter...
#33
Anyway yes, I would also recommend doing one mod at a time. It is more work but you get a feel of what you like and what you don't like. Also it's a lot easier to debug than adding a whole bunch of new stuff and then have problems, and not know where to start looking first.
#34
That makes good sense. Does everybody agree that the shift kit is good from the start? What about the meth kits, from what I hear they help cool off intake temps. It was 81 degrees today here in Louisiana...you can imagine what the summers are like.
#35
Meth/water will help keep your iat down. But a little word of caution, don't reply on meth for fueling if you don't plan on checking it every day. I would suggest a meth kit with 50/50 mix.... There are a few good set-ups around. I personally like ALKYControl..
#37
Like I mentioned I have the snow performance meth kit that taps into your whiper fliud reservoir that way you have a built in low level indicator and dont have to check it daily.
#38
Fast86z
08-23-2015 12:35 AM
