Magnacharger and Spray?
#41
Truck Sponsor
You can srpay sooner then 5k with a 100shot. But its not needed. Blowers that make a lot of heat love nitrous. Well all blowers love nitrous. lol Getting a progressive controller that will controll you heater, tap into your wideband, was a window switch, tps switch, multi point ramping, psi into if using a Trick or FJO wibeband. I got the item for you. Give WJmark a pm, he has sprayed his truck, not blower but can give you some data on this item. You can ramp backwards was well, turbo guys like that feature a bunch.
http://www.trickperformanceproducts.com/tpp_00019.htm
#44
What meth kit do you have? Is there a logic to how much you run or what kind to run? Stage 1.... Stable 2..... Stage 3. (Snow Performance)
#45
Went to 11psi and 55hp shot and iat temps are 160* and timming is at 12*..... Went to a 75hp shot retarded timing 2* and at the launch the timming went to 8* with 4*kR. So confused...... Where do I go from here?
#47
10 pounds of boost on a tahoe will last 2 runs maybe three and then you will be off to the tranny shop. you need a 4l80 truck is to heavy been there done that. I have now put in a 4l80 forged the motor ran a 100 shot with 10 pounds and ran 12.17 with 20 inch rims.
#48
Destroyer of Transmissions
