magnavolt issues
Old 01-06-2007, 02:12 PM
2004SSS's Avatar
well i got fed up of waiting and ended up driving down there on thursday to pick it up, now the truck runs good. but man that was a long *** drive almost 6 hours round trip during rush hour traffic.
thanks for the help joe, i was reading your post on the ssr forums and i was seeing you could fuse the ac press switch and it should stop the magnavolt from blowing diodes?can you elaborate?
Old 01-07-2007, 08:21 PM
FormerVendor
leftcoast32's Avatar
What we have been doing is filling the A/C Pressure Switch with DieElectric Grease so the water doesn't lay in the switch head and short the 5 volt reference signal.
Old 01-07-2007, 08:25 PM
2004SSS's Avatar
hmm, so this is the pressur switch at the top of the back wall on our trucks? the tank wrapped in alumin foil stuff? i know the switch is easy to change but the pig tail comign off you just cover in di electric or what?
Old 01-07-2007, 10:48 PM
WODY's Avatar
unplug put some grease in the connector plug back in. i think i'm gunna do that to mine i was walking to my truck the other day and i could hear a clicking under the hood and once i popped the hood i felt the switch and that was where the clicking was coming from. i don't have anything close to chase's setup but i'll give the grease a shot.
Old 01-08-2007, 07:19 PM
FormerVendor
I would have to look under your hood to see where they place it in the trucks. On the SSR and a few others it is right below the belt tensioner in the aluminum A/C line off the pump.
Old 01-08-2007, 10:12 PM
2004SSS's Avatar
ok so its on the other pressure switch there is one on the condensor, and one on the actual pump at least that is where i think it is .
Old 01-09-2007, 08:20 AM
FormerVendor
You will notice that the switch is put so that it acts like a cup and will hold water if it gets any on it. This is why the DieElectric Grease helps.
Idryfly5
09-02-2022 08:55 PM
murderedSS
27
10-12-2015 11:13 AM
TAPyvehc93
09-14-2015 01:22 PM
dselby25
09-11-2015 05:03 AM
Boyes50
09-08-2015 12:06 PM
Quick Reply: magnavolt issues
