Making the turbo louder? at idle
Just wondering about this, I see some videos of STS turbos on silverados and you can hear the turbo whistling while the truck just sits there at idle. Mine is crazy quiet, you can't hear it at all until it goes into boost (which is somewhat a good thing, from a stop to about 3,000rpm people think it's just a stock truck w/ exhaust)
I know that on the dodge cummins (garrett turbos) people remove the silencer ring at the inlet of the turbo. I have a master power 70 turbo, I'm pretty sure they arn't made the same, but wondering if there was anything that could be done?
I duno if you have a rear mount or not but they typically have an extremely short downpipe, like less than a foot in most cases...... I always figured this made em whistle a little louder
I did stumble across a Wrx sti post though, where they removed the silencer on the turbo and it cause the turbo to be louder
02z71-- explain? lol
The sts turbos (Garret) are more noisie. Mine was really loud. I had the gt67 ball baring turbo and it was loud at idle and just daily driving it. I loved it. I have the turbonotics t-62 on my wifes avy (rear mount) and you cant hear anything. the t-62 has a 4 inch inlet. the garret has a 3 inch inlet. I don't know about the MP70.
Put a cut out right after your downpipe connects to the exhaust. Just open it when at idle or slow rolling a parking lot. I drove mine on an open down pipe for a little while and it whistled like crazy. It got real quiet at idle after the exhaust went on.
A ball bearing turbo will be more prone to "whistle" at idle and low rpm because they spool so much easier from the less resistance from having a ball bearing center cartridge. A normal thrust bearing center cartridge turbo will never spool as fast as a ball bearing of the same size, thus less sound at idle.
