Manacharger Coolant Disappears
Old 11-03-2010, 01:42 PM
Rick_Vor's Avatar
Originally Posted by OnyxSilveradoSS
my friend had his internal core leak...the replacement was not too expensive from MAggie.
If it's an internal leak, iI wonder if it's something you could have a radiator shop solder up?
Rick
Old 11-03-2010, 02:52 PM
SILVERADO11's Avatar
I would take a guess at it being the intercooler core leaking inside the supercharger, may have to pull the blower off remove the intercooler core and have it pressure tested. If there is a leak i dont see why a radiator shop could not weld it up for you. Or you could upgrade to one of tricks bigger and better intercoolers he has. good luck!
Old 11-03-2010, 04:45 PM
11 sec. Truck Mod
TIM Z's Avatar
Drain it and use compressed air to fill up system, 10-15 psi should be a safe start. Then get a spray bottle with soapy water and spray your hoses and connections/ Heat exchanger.
If no bubbles on out side of system tare apart that blower and test the HEX
6.0l RST
11-23-2015 11:30 AM
bearden86
26
11-15-2015 03:58 PM
sTNT971
09-26-2015 04:22 PM
Pimpinpete
09-08-2015 07:39 PM
Quick Reply: Manacharger Coolant Disappears
