MAP Sensor
MAP Sensor
Finally got everything set up on the truck. Went to go get tuned but my tuner said I needed a 2 or 3 bar map sensor, he didn't have one in stock, neither did any of local performance shops near me (Houston).
I was told that the Cobalt SS one might work since the colbalt has FI.
Anyone know if a Colbalt SS (from what year) sensor will work on my 2006 Silverado 5.3 w/ stock intake? And if it works is the same one that an Auto parts store like AutoZone and O'Reilly's carry?
I think it's a BARO sensor for a Cobalt SS. I'm not sure as I eventually found out it wouldn't work on the newer trucks. The part number I was given is:
PN 12615136
I hope that helps, it should look exactly like your stock MAP.
PN 12615136
Would this one work on boost? Or should I go for the AC Delco one ($135)
http://www.oreillyauto.com/site/c/de...ord=map+sensor
Cam specs 216/220 .560/.560 @114lsa monitoring w/ AEM TruBoost and AEM Wideband.
Is a PCV for a turbo required
yes! without one you are boosting the crank case, i have an upgraded one in the stock location from a ford turbo t-bird..
i have the part number posted in my build thread
https://www.performancetrucks.net/fo...thread-504600/
