Max Boost on 44lbs injectors
Old 09-18-2007, 01:18 PM
Default Max Boost on 44lbs injectors
I am finishing up my front mount turbo. What would be the max boost I can run on my 6.0 using 44lbs injectors? I also have a set of 50lbs injectors I could use but i have to switch out the pig tails. What size should I use or what would be recommend?
Would and inline 255 fuel pump be enough?
Old 09-18-2007, 01:29 PM
vanillagorilla's Avatar
It's more of a question of power really, not boost. Could you tell us some more about your setup (turbo size, is the engine built, heads, cam etc.)? What are your goals?
Old 09-18-2007, 01:47 PM
It is a front mount T-72 turbonetics w/4" down pipe, 6.0 lq4 w/rod bolts, proted oil pump, LS2 timing chain, 317 heads with a little work, 918 springs, pushrods, and cam.
Old 09-18-2007, 02:04 PM
zippy's Avatar
I'm assuming this is for a pre-04', you should be good with a turbo'd 6.0L to about 6psi. By 8psi you will be well into getting lean at higher rpm.
Old 09-18-2007, 07:55 PM
03sierraslt's Avatar
When I pulled my 44's off I was at 7psi and was seeing 112-115% duty cycle at 5650rpm. The 60's I have now are at 59-60% at the same boost and RPM.
Old 09-19-2007, 07:58 AM
slowec's Avatar
Sounds like your 44's belong in the classifieds
Old 09-19-2007, 08:48 AM
I say go with the 50's, but I'd rather see 60's on there so you could take advantage of that turbo a little more.
Old 09-19-2007, 08:54 AM
How do I change this text
Wilde Racing's Avatar
I've ran 14 psi with 44 pounders.
And lots and lots of meth.
Old 09-19-2007, 09:00 AM
Yeah, he didn't mention meth, so I'm assuming he's just running gas, so he'll need bigger injectors.
Old 09-19-2007, 05:18 PM
365ZUM's Avatar
Strange... I have 44lb injectors in my 06' LQ9 and run ~9lbs or so full time. Besides an MSD Boost-a-Pump, my fuel system is stock. No pinging whatsoever, and my A/F (though I can't recall the exact number) is actually too rich, even at high RPMs. Meth is installed, but not injected.
As long as you have a good, safe tune IMO you'll be fine with the 44's.
Quick Reply: Max Boost on 44lbs injectors
