max boost on a 5.3 and straight 93 octane
Old 02-18-2012, 04:53 PM
ayousef's Avatar
Originally Posted by blue0453
13psi here. hasnt blew up yet. running low timing and meth..
how much meth are you spraying, and im assuming 93 octane? Also any idea at what RPMs do you make peak power?
that should help me out a little bit.
Old 02-18-2012, 08:46 PM
blue0453's Avatar
Im spraying the biggest nozzle that came in the kit..As far as power for some reason the truck isnt pulling past 5k. I made 486 at around 4600.
Old 02-19-2012, 06:36 AM
ayousef's Avatar
Thats probably a function of small turbine housing a/r.
What turbo (compressor and turbine) is on that truck if you dont mind? Sorry if you have it in your signature but im using the phone and cant view them.
Old 02-19-2012, 07:23 AM
blue0453's Avatar
I have a master power t-76 with a .96ar
Old 02-19-2012, 07:24 AM
blue0453's Avatar
3" down pipe ran into a 3" in/out magnaflow run all the way to the back.
Old 02-19-2012, 03:20 PM
ayousef's Avatar
is that power curve the norm with a 76 0.96a/r on a 5.3liter motor or does this have anything to do with the cam?
Old 07-15-2012, 05:01 PM
mad max 777's Avatar
Actually it was a 5.3
Stock GM LS Engine - Big Bang Theory - Hot Rod Magazine
Old 07-15-2012, 05:35 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by mad max 777
Read it further. They found out later it was a 4.8L not a 5.3L.
Old 07-17-2012, 02:13 AM
Your are correct sir! I miss read the article!
Old 07-17-2012, 07:09 AM
Choda's Avatar
so my goal of 500 wheel on trick stage 2 70mm, pump 93 without meth or cam is pretty well shot?
I figured 12 psi on 93 would get me there. i made 377rwhp on 5 psi. Was really hoping all i needed was a trans and fuel.
I really dont want meth or start "building" the motor for 500 wheel.
Quick Reply: max boost on a 5.3 and straight 93 octane
