Meth heads inside.
Old 06-14-2008, 01:15 AM
  #21
Truck Sponsor
Wheatley's Avatar
Originally Posted by 1Bear
No joke, Julio took my order over his cell as he was driving down the road. We talked over what I needed as it was a custom order and within two hours I had a tracking number. Just remarkable service!
Alky control is what I would get for sure
Old 06-14-2008, 01:22 AM
  #22
Originally Posted by Slowhawk
Julio at Alky control hands down.I've probly bought close to 30 kit's off him.
You can run 10lbs without meth no problem,but the truck with be faster with meth.
thats what everyone keeps saying is that i can run 10psi but i could not, dont know why? i want to see some else's setup running 10psi
Old 06-14-2008, 01:29 AM
  #23
Truck Sponsor
Wheatley's Avatar
What was goin on that you could not run 10lbs?
Old 06-14-2008, 07:35 AM
  #24
LS1Tech Sponsor
Slowhawk's Avatar
You can run 10psi,I did without meth BUT the timing needs to be pulled pretty good due to the load of these heavy trucks. The meth helped me add 4-5 degree's of timinf which really woke up the truck.
Old 06-14-2008, 08:41 AM
  #25
Truck Sponsor
TrickTurbo's Avatar
Once the FJO units are ready to ship we will be stocking them. The computer controlls are very nice, and I understand they have added some other features that make the units even more user freindly.
The current set up allows injecting different amount through out the rpm/boost ramp. Depending on needs..
Colton I will give a buzz once I have them in hand.
Old 06-14-2008, 11:36 AM
  #26
charcold-bowtie's Avatar
thanks rick. Just seeing what everyones opionion sp is. I had my truck up to 9 psi with the timing table that was in it. I made no immediate changes. It would run the IAT up there pretty quick.
Old 06-14-2008, 12:42 PM
  #27
we had no timing in the truck, somewhere around 15 degrees and we turned the torque management back on cause it would knock between the 1-2 shift, did not help
i think i am going to go to a speed density and meth then start from scratch with the tuning
Old 06-18-2008, 02:36 PM
  #28
LS1TECH, Trucks, Modmotor Sponsor
LivernoisMotorsports's Avatar
Originally Posted by trever1t
AlkyControll, the best kit hands down and Julio's customer service is 150%. It is progressive and fully adjustible.
Agreed! These are the only kits we run. We've run others in the past and none come close to the quality or performance of this kit and their service is excellent!
Regards,
Rick LeBlanc
Livernois Motorsports
Old 06-18-2008, 02:57 PM
  #29
WJ MARK's Avatar
I have a basic Devils own kit on a hobbs switch kicking on at 8 psi. It definately got rid of the det. I run close to 12 psi on my truck, Without the meth I have the same problem as you.
Silveradorst07
12-31-2015 12:04 AM
greedygenius
09-03-2015 06:51 AM
cosb
08-24-2015 09:08 PM
tim wellington
07-31-2015 03:28 PM
fcompean
07-15-2015 09:55 PM
Quick Reply: Meth heads inside.
