Meth heads inside.
#24
LS1Tech Sponsor
You can run 10psi,I did without meth BUT the timing needs to be pulled pretty good due to the load of these heavy trucks. The meth helped me add 4-5 degree's of timinf which really woke up the truck.
#25
Truck Sponsor
Once the FJO units are ready to ship we will be stocking them. The computer controlls are very nice, and I understand they have added some other features that make the units even more user freindly.
The current set up allows injecting different amount through out the rpm/boost ramp. Depending on needs..
Colton I will give a buzz once I have them in hand.
#26
thanks rick. Just seeing what everyones opionion sp is. I had my truck up to 9 psi with the timing table that was in it. I made no immediate changes. It would run the IAT up there pretty quick.
#27
i think i am going to go to a speed density and meth then start from scratch with the tuning
#28
LS1TECH, Trucks, Modmotor Sponsor
Regards,
Rick LeBlanc
Livernois Motorsports
#29
I have a basic Devils own kit on a hobbs switch kicking on at 8 psi. It definately got rid of the det. I run close to 12 psi on my truck, Without the meth I have the same problem as you.
