Meth Injection
This is becoming very tempting... another 40 hp for 500 bucks sounds like a fair deal to me. That and a couple more lbs of boost, a cam... and I'll be on my way I'm looking at using my windshield washer resevoir so i can utilize the low level inicator and keep the engine compartment uncluttered. Sound ok?
+1 i have my pump pull from my washerfluid tank so the DIC tells me when its low. Also i have a led that is next to my wideband that lights up when the pump comes on. So i know at all times when its spraying. If you wot without meth with the added timing you will pop you motor. A buddy of mine even has his setup on a siren if its not spraying it will sound. You must tune for it or you are actually gonna run pig rich and you will loose HP
