Meth Injection
Old 10-05-2009, 10:55 AM
  #21
BigCountryx's Avatar
So a Snow Stage 2 would be a good kit to go with? Waiting on my tuner to get back with me about the whole deal. Love the LED idea, I want to know it's pumping for sure! Do you have some sort of flow meter that send the signal? Thanks guys, keep the info coming.
Old 10-05-2009, 11:46 AM
  #22
charcold-bowtie's Avatar
I run a snow kit.
The LED just means the pump is working. If you have a wideband, it will show you when its working. If someone makes some sort of AFR failsafe, that would be really cool too.
Old 10-05-2009, 12:14 PM
  #23
So your led just shows that the pump has power, not that it's running, that's cool. I think snow makes all the add ons for fail safe conditions.
Old 10-05-2009, 12:22 PM
  #24
Midnightrider's Avatar
in theory yes when the controller tells the pump to spray is when my led lights up but you can see in on the wide band too
Old 10-05-2009, 02:43 PM
  #25
I AM A MOTHERF*CKER
TurboBerserker's Avatar
the alky kits have a "has power" led and a "spraying" led -- at least on my progressive kit.
Old 10-05-2009, 03:18 PM
  #26
sharpshooter's Avatar
Man this thread really has me looking into meth now.I never really had an IAT problem but it seems there is a lot more benefit than just IAT's.
What degree of timing have most of you peaked at with meth? There has to be a point where adding timing doesn't result in anymore power.
Old 10-05-2009, 03:20 PM
  #27
on my radix setup i was peaked at 21 degrees no KR probably could have gone hirer
Old 10-05-2009, 03:52 PM
  #28
Mort's Avatar
Originally Posted by KySilverado
I start spraying at 2psi. Ramps up pretty quick. Alky control kit. **** at 5.
Thanks for the settings you are using! I have mine at 4 psi and **** at 4 so I will play around with it a bit. If I bring it in too low it just drinks meth at low boost and part throttle. Think I might leave mine at 4 psi and tune my Boost VE table from there up with the meth and set the **** to 5. I will set the low boost to 11.5 on fuel only and see how that works. I use methyl hydrate and it is about $9 - $10 a gallon here. Alky control kit here as well.
I have the same kit and my red LED comes on when the system is activated and the green LED comes on when it is at full steam.
I think it also has a lead that you can use to switch your boost control on a turbo so you only go on high boost if the meth is working.
Alky control kits are MAP activated on GMs and MAF activated on Fords.
Old 10-05-2009, 04:16 PM
  #29
TX Tahoe Z71's Avatar
So MAP activated is the way to go for GMs? And I have heard nothing but good things about AlkyControl kits, so I think I'll give them a call.
Old 10-05-2009, 04:26 PM
  #30
2nd fastest 5.3 ECSB
trever1t's Avatar
I have one also. Mine is set to '6' and 'come on' ~5psi
Quick Reply: Meth Injection
