Meth Injection
#21
So a Snow Stage 2 would be a good kit to go with? Waiting on my tuner to get back with me about the whole deal. Love the LED idea, I want to know it's pumping for sure! Do you have some sort of flow meter that send the signal? Thanks guys, keep the info coming.
#22
I run a snow kit.
The LED just means the pump is working. If you have a wideband, it will show you when its working. If someone makes some sort of AFR failsafe, that would be really cool too.
#26
Man this thread really has me looking into meth now.I never really had an IAT problem but it seems there is a lot more benefit than just IAT's.
What degree of timing have most of you peaked at with meth? There has to be a point where adding timing doesn't result in anymore power.
#28
I think it also has a lead that you can use to switch your boost control on a turbo so you only go on high boost if the meth is working.
Alky control kits are MAP activated on GMs and MAF activated on Fords.
