Meth Injection
#31
Just out of curiousity....if you ran meth on a progressive setup, and assuming you are using the windshield wiper reservoir, on average how long will that last? This is assuming a daily driver situation where you are in and out of boost--not just at the track.
#38
Give Julio a call at AlkyControl, he is worth talking to. Very personable service and first class parts.
Snow's have lots of kits but look at stage three. I also think you want MAP not MAF control. Are you or will you be running SD then MAP control for sure.
Also a lot of guys like Devil's Own.
#39
I have a Alky system sitting in the garage waiting for me to install a new shortblock. I'll definetely have that one set at 5lbs intitial boost.
BigCountryx Skip the Snow and go straight to Alky Control. Pretty $$$ but much higher quality of components, fittings, Stainless Steel braided lines, etc. It will come with a washer tank prefitted with the correct fitting for the pump and your low fuild dash light will remind you if it gets low.
Rick
