1 year warranty on the pump. Mine failed somewhat after that. The fitting in the tank needs a better design. Just a grommet and push in fit. Over time mine starts to leak. Have to pull it out flex work with it to get it sealed again. No biggie just a hassle.
Did you tap your stock tank or did you use the replacement tank that Alky provides and taps themself?
I used the alky control tank. Best I remember it is no different than the stock tank. No tapping goining on. They basically give you a stock tank with a brass fitting stuffed into the factory grommet with the barb to hook up the pump line.
So I hit +70 from ambient today when I put on the 3" pulley making 11lbs on the tvs1900, so meth crossed my mind. Southern heat and humidity is ridiculous
