Meth injection!
I have a sts kit that I took off a guys truck. So I'm not sure on kits either but I know you want a progressive one not just on off. Devils is like that. You set "on" boost pressure and full tilt spray boost pressure and how much you want it tamped up in between. As in how fast you want it to go to full spray pressure. This way you can tune you injectors to work with it instead of against it.
11 Second Truck Club
I have the devilsown kit with the progressive controller, works perfect for me. I was using it when I was running reg. 92 gasoline, but I don't use it now with e85. The kit I got was complete and easy to install.
I knew someone might bring that up lol. Everything I bought for the setup was all on ebay at a way discounted price, so I made off pretty good. Even my turbo was only $500 new, theres a guy on the forum now selling his used s475 for like 750.
Which kit is that? Link? Or willing to sell your old kit?
+1 Alky Control...I went 100% meth mainly to cut IAT's and hopefully tweak timing and hold off KR a little longer! Wheer u are IAT's will always be an issue. Only issue is that the blowers and turbos really dont like the stuff over time I'm told. So far no probs here and its helped lots, but the guys over @ maggie didnt recommend it. IMO...the tuning will make the diff as to how much and when it comes on. All u need is 1 nozzle, and u can change the size/flow as ur power increases. The common weakness in ALL is the pumps tend to fail, but they have gotten better....
I posted a link. Where did it go. http://www dot alcohol-injection.com/ls1-7-stage-2-49.html
I've been running a devils own kit for 4+ years now. I lost a pump about 2 years ago which Chance replaced at cost for me. Said his pumps are much better now and 100% meth compatible. I just use the WWF reservoir (built in warning light ) and run WWF most of the time unless I'm going to the track. Then I drain it real quick and run 50/50 Meth and WWF so its about 80% meth.
