meth pics
Old 06-24-2009 | 02:10 PM
MFIC's Avatar
Here is a couple
Mine
Eric's ZO6
Stev's TBSS
Old 06-24-2009 | 02:19 PM
Most Hated's Avatar
just had mine installed yesterday a lil dirty huh
Old 06-25-2009 | 01:55 PM
nonnieselman's Avatar
Im workin on installing a Devils Own currently.
Waitin for my Tanks to show up so i can finish it up, I have some pics but ill wait till im through to post everything at once.
Old 06-25-2009 | 02:51 PM
Superado's Avatar
11 Second Truck Club
anyone have problems with the tubing and push-fit connections leaking?
Mine did after a short time with the DevilsOwn tubing as well as some I picked up form The Home Depot...they work for awhile, then start leaking under pressure.
I guess I need to go to braided lines...
Old 06-25-2009 | 02:53 PM
You talk to Devils Own? They are good at resolving problems like that.
Old 06-25-2009 | 03:29 PM
fastnblu's Avatar
Originally Posted by Rick_Vor
Me three. Ran a snow kit for about a year and just upgraded to a dual nozzle Alky kit.
For the Snow Kit, I made a sheet metal shelf and I mounted everything on the passenger inner fenderwell. Single nozzle about 8" from TB.
Rick
OP, not to jack but even before you posted this, most seem to run AlkyControl or Snow. Rick, was there a reason ya ditched the Snow? Is A.C. a much better kit? Most haven't used both. You have. Pros/ cons to each kit?
Old 06-25-2009 | 03:38 PM
Superado's Avatar
I mentioned it in an instant message awhile back when I thought the Home Depot tubing was gonna work...not since...
I'll hit him up on AIM...
Old 06-25-2009 | 03:43 PM
Phantom's Avatar
11 Second Club
I have a ? Does it matter how far from the TB you mount the nozzle(s)
Old 06-25-2009 | 03:55 PM
Superado's Avatar
ask 6 people, you'll get at least 4 different answers...
I did have mine originally tapped into the TB itself...one small jet
I now have two much larger nozzles mounted further back to have, in my mind, a better mix with the air before hitting the TB...after one bend and well before the last bend...
Old 06-25-2009 | 04:14 PM
Superado,,,, is yours goin thru the IAT sensor?
