Meth pump failing
Old 05-02-2008, 03:09 AM
9 Second Truck Club
stock48's Avatar
Unhappy Meth pump failing
I have noticed my AFR going to the high 12's about every time I get into boost. How long do the pumps last running straight meth? They told me at snow it's not rated for 100% meth. Is 2MOS as long as they last @100%.
Old 05-02-2008, 08:13 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
I run straight meth, have daily for 2 years but I use the Alky pump. Meth is very corrosive to certain materials like aluminum and such.
Old 05-02-2008, 08:25 AM
KySilverado's Avatar
My alky control pump failed after a little over a year. Never lost my AFR. Just leaked while sitting around.
Old 05-02-2008, 09:26 AM
dhpro's Avatar
Snow is not ideal for 100%, thats why I switched to AlkyControl...did they offer to swap ur pump? R/
Old 05-02-2008, 11:42 AM
Assuming the question was to me. No they didn't offer to swap the pump. Send it back kind of thing and would try and repair it. Claiming pump failures were rare and probably due to contaminated fuels running through it. The seals just failed. Pump side and pressure switch. I just bought a new one.
Old 05-02-2008, 11:48 AM
High on diesel fumes
thunder550's Avatar
My original Alkycontrol pump failed too after about 2 years. I bought the upgraded one, which I understood to be 100% meth compatible. Did you guys understand that the same way, or am I making things up?
Old 05-02-2008, 12:12 PM
Yes the Alkycontrol pump is 100% meth compatible.
Old 05-02-2008, 12:20 PM
thunder550's Avatar
Koo, thanks
Old 05-02-2008, 12:21 PM
How do I change this text
Wilde Racing's Avatar
alky is NOT fuel compatable, that is what kills the pumps....
Old 05-02-2008, 12:22 PM
thunder550's Avatar
Hmmm.....well that would make sense...I have used gas cans to store my methanol in.
Quick Reply: Meth pump failing
