Meth System Layout and Decission
Old 04-12-2007, 07:27 AM
Lord Aries's Avatar
Check this set up out, another member was kind enough to send me it... looks pretty slick and the price isn't too bad... It has a progressive controler and such...
http://www.enginerunup.com/shop.php/...d-kit/p_8.html
Old 04-12-2007, 08:11 AM
8ALTNG's Avatar
I have a snow kit on my truck. 2 nozzles (the biggest ones they had). I run the meth out of my windshield washer tank and the windshield washer fluid out of the meth tank. That way when I am low on meth the light will come on on my dash.
Also get the bigger sized pump. And get a one way check valve. That way when you spray the meth it is there then, not 3 seconds later.
Old 04-12-2007, 08:57 AM
Lord Aries's Avatar
Yea, i like the idea of the tank set up like that...
The meth i posted above your post has the parts you mention included with it...
Old 04-18-2007, 03:45 PM
FlaBouy's Avatar
Stage 2 Snow kit here with relocated IAT sensor 6" ahead of the TB. I spray a 650ml nozzle at full voltage about 8" before the IAT sensor to get good atomization before the sensor. It adds about 1/2 percent AFR to the fueling when running a 50/50 mix. Will drop my IAT temp on my non-intercooled Vortech from 135* to 80* instantly....
Took me a few days to tune the added fueling out with HP Tuners, not that I need the fueing anymore with the 60# injectors...
I set the progressive controller up to start spray at 1 psi of boost and am full spray at 6 psi. I run 13 psi of boost as recorded on the 2 BAR MAP at 190-195 kPA.....
You might want to run logs against cylinder misfires when you first install the kit to make sure your nozzle sizing is correct. Nozzle sizing is a product of HP output of the motor.... one size does not fit all...
Hope this helps.
Old 04-18-2007, 07:28 PM
Lord Aries's Avatar
Good info, thanks!
FlowmasterMufflers
11-24-2015 01:00 PM
Mr. Chainsaw
10-18-2015 08:00 PM
Superman09
09-25-2015 05:55 AM
Justin87gn
09-10-2015 12:06 PM
Quick Reply: Meth System Layout and Decission
