METH Woes....Input would be helpful
Old 09-14-2011, 04:41 AM
11 sec. Truck Mod
TIM Z's Avatar
Wouldnt the incoming meth spray fill the gap between the rotors, hence " sealing up" the gap and help to not lose boost?
Old 09-14-2011, 04:46 AM
Mod with training wheels
smokeshow's Avatar
Originally Posted by EVILGMC
one issue with the post-blower (spacers etc) setup is fighting the vacuum. the check valves supplied with the kits are not strong enough.
My first thought was "get a bigger cam" so you could drop that vacuum down to something more reasonable Then I read about the California smog problem...
The methanol is part of the incoming air charge, so it would bleed past the rotors just as well.
Old 09-14-2011, 05:07 AM
Jontall's Avatar
Some facebook chit i came across....apparently the meth ate the coating off the rotors. I emailed the speed shop to get more details, but still a concern considering the number of us running some sort of meth/water injection and maggie/whipple/roots style blowers
"Still want to inject water/meth PRE THROTTLE BODY on a roots/screw blower? Look at the coating blasted right off these Eaton TVS rotors!" -photo caption from FB
That's a factory defective coating and it's been discussed. Ask Brian "Blownchevy".
Old 09-14-2011, 05:38 AM
03sierraslt's Avatar
I was wondering, that seems a bit excessive unless someone was spraying a **** tone of meth. That pic was posted in one of my threads, an while i know meth is corrosive I also put about 2k miles on mine a year so i dont imagine ill be using much meth.
Old 09-14-2011, 08:38 AM
EVILGMC's Avatar
I emailed the shop (blue collar performance) asking for some follow up and this is what he said....
"None that I can share, except you really should NEVER inject pre-blower on ANY roots, especially a TVS with coated rotors."
Old 09-14-2011, 10:33 AM
Where is Brian when you need him?
Old 09-14-2011, 11:17 AM
EVILGMC's Avatar
Since the publisher of the photo refuses to answer any questions about the complete package, it is very tough to determine what really happened here. too many variables.
Old 09-14-2011, 12:11 PM
kbracing96's Avatar
It's BS, no way the small amount of meth that actually gets sprayed in relation ship to the amount of air coming though the supercharger could do that. Meth is usually in vapor form by the time it gets to the rotors any way. Meth is only corrosive to aluminum when it sets for a long period of time in direct contact with it. I'm sure that was a coating issues, cuz there is WAY to many guys spraying Meth through TVS's (including me when I had one) for that to be a problem. Internet BS if you ask me.
Old 09-14-2011, 12:38 PM
Man Motor club
rjwz28's Avatar
Look at the differences in coating even between the two rotors; the one in the foreground has way more damage to the coating than the one in the background. Seems more likely related to coating quality; otherwise shouldn't both rotors show similar deterioration to the coating?
Old 09-14-2011, 01:24 PM
Baltimore Whore
Mangled03gmc's Avatar
YOU SEE WHAT METH DOES TO TEETH???? THIS IS NOT SURPRISING..
Quick Reply: METH Woes....Input would be helpful
