Methanol alternative
Old 07-20-2015 | 11:38 PM
Jetn3's Avatar
Default Methanol alternative
I've been looking and I can't get any meth where I live. All washer fluid is +32* and no one will ship overseas to Hawaii. Only thing here is yellow Heet and Home Depot denatured alcohol.
Anyone use/tune with denatured alcohol?
Old 07-20-2015 | 11:59 PM
George C....'s Avatar
Formerly ScreamingL
You can use heet or denatured alcohol but why not just run less timing and have a safe setup
Old 07-21-2015 | 03:39 AM
Jetn3's Avatar
Well I'm @ intercooler 10psi on 92 pump gas and want to be able to safely turn up boost (14-15psi max)using meth or other cooling agent.
What ratio of water/heet or denatured alcohol is used if pure meth is not available?
Old 07-21-2015 | 09:58 AM
Formerly ScreamingL
i have a built running around that is 16psi on straight 93...11.0 cr and a max of 13* timing
i pull timing for that build based on IATs early and it still makes good power on 8* timing which was 744 on a mustang dyno and at 13* it made 806 rwhp
so for 14 psi you can run without meth if you choose to
i dont know the ratio or etc but you will need to be tuned for it
Old 07-21-2015 | 10:03 AM
sprayedenali's Avatar
you can order "boost juice" im sure
Old 07-21-2015 | 10:18 AM
Atomic's Avatar
I have a gauge for that
Try to find a VP fuels dealer, they should able to get M1 for you.
Denatured alcohol is essentially e85 fwiw.
Old 07-21-2015 | 11:11 AM
Y2KLimited's Avatar
HAWAII
Honolulu - Mechanical Mayhem
Phone: 808-841-2467
kevin@mayhem808.com
Old 07-21-2015 | 02:44 PM
Jetn3's Avatar
Cool man, thanks. I'll check him out
drummer0415
11
10-24-2015 09:16 PM
sTNT971
09-26-2015 05:22 PM
Benloe
09-22-2015 11:24 PM
