modify LQ4 fuel rails? for AN fittings?
Hey guys
just wanting to know if youve ever modified these stock plastic truck rails to accept AN fittings?
im going twin turbo on my 67 camaro and have an lq4 motor and lq4 intake...
thanks
thanks
There are fittings that you can buy thru summit or whatever that will adapt to the stock quick connect fitting on the rails and have a an that you hook your feed line to. Are you wanting to have the billet style setup... With inlet on one a crossover up front then exit out the other. You can get cheap billet rails for like $100 if you want.
I dont think I would mess with that. Could it be done, most likely but how safe. Its not worth it, get some aftermarket rails and be done with it. In my opinion there are certain things that you dont want to go cheap on (not that rails are that much)and fuel is one of them. A fuel leak can get ugly.
You might be able to weld a fitting to the end... but like everyone says, why chance it. Also I don't know if the dampers inside(the springs and flappers inside the rails) are made for flow in a different direction than stock. I have a set of factory fuel rails I would sell you, if you want to try something on them first.
You could cut the quick disconnect off, and use just use a hardline fitting to get to AN.
Aeromotive may can help you, I think that is the opposite of what your wanting tho
https://ls1tech.com/forums/fueling-i...fuel-line.html
Rick
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
