more boost from whipple? also low vacuum on the highway
Restricted User
i currently have a 6.0 with a sidemount whipple supercharger. 224 duration camshaft that was custom ground for boost. i am making 6lbs and peak at 7lbs. my pulley is 3 5/8. i would like to go smaller but whipple guy said thats the smallest they make for my blower. i have the single belt system, i was also thinking about the innovate west pulley, but i would ratther down size the pulley if possible
my other question is that at cruise at 70mph it always stays around 0psi and no vacuum. i am wondering if it is something that can be adjusted witht the bypass valve or maybe use that solenoid to control it on the highway so i make vacuum.
i am only running 44lb injectors so i have to come up with some bigger ones befor i make more power but i would like to get things figured out. thank you for your input
